Passes
miohn
sorry! I don't get it atm.
How can I render out an object with reflections (from the surrounding objects - not hdri)
without the surrounding objects.
Like I normally would do with comp-tag/object buffer - not seen by camera but
sending GI and reflections.
thanks
Mike
glimpse
answer: You can't =)
the way to do that is like rendering two /or as much as You need/ images and then doing photoshop work =) but in some situations it's not the best solution =) thought it works if You need solution badly /including cost of render time =)
SVITAdmin
indeed, you can't.
Ive heard rumors that a future version will support composting tags
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
need new features on Octane Standalone for that, like object visibility option
miohn
o.k. thanks.
So I'll work with C4D Passes.
one other thing please!
I'm trying to make a slightly blurred glass material which is illuminated inside.
I cannot get this to work.
Any idear how to set this up?
Can I place simply a light inside a glass cube?
Rendertime is of course an important aspect.
thanks
Mike
SVITAdmin
miohn wrote:o.k. thanks.
thanks
Mike
use an object with a blackbody emission on it for the light. place that in a glass object. adjust the roughness on teh glass to adjust blur
currently working on a project that utilizes this method
miohn
thanks!
Will try that method!
regards
Mike
