Video texture from C4D
electromusic.se
Is it possible to use video textures when exporting for animation?
MacPro 2008 8 core / 8 GB Ram / GTX 680 / GT 120 / Mountain Lion / Cinema 4D R14 / Octane Render 1.10
face
Nope...
After reloading a scene in Octane, Octane use the materials from the ocs file.
A change in the obj/mtl will also have no effect.
One solution is to change one texture at every frame.
e.g
If Octane is finsh, the export overwrite texture.jpg with frame2 from the video.
Octane then load the changed texture.jpg and render the next frame of your animation.
face
http://vimeo.com/user2509578
abstrax
electromusic.se wrote:Is it possible to use video textures when exporting for animation?
At the moment there is no way to do it with the exporter. And as face already said, it's not trivial, but also not impossible. In the very end you "just" have to replace an existing texture file with the new version and Octane would then use this one for the next frame. Of course, the best way would be, if the exporter supports this. -> I have made a note in my todo list.
Marcus
electromusic.se
This would be a real hammer. Think about the comping possibilities. 8-)
/Bjorn
u7angel
bump
abstrax
Thanks for the reminder. I just didn't get around to do it yet. After beta 2.5 I will do some more work on the exporter. A few small changes and a bug fix have already accumulated.
Marcus
enigmasi
I tried to do as image sequence too but it didn't work :)
octane renders only with first image
u7angel
bump :)
colorlabs
I thought I had tried image sequences and had good results... did you try this? C4D has good image sequence support.
Mac OS X 10.8.0 | ASUS GTX 580 1.5GB | MSI GTX 470 | ATI Radeon 6870 | Core i7 2.9Ghz | 16GB
face
It doesn´t happens because Octane use the mtl-file only on a new scene...
face
