rayfire with octane ?
HHbomb
Hello
Is there anybody who use Rayfire with octane ?
I tried demo and watched a lot of tutos, but rayfire use a lot visibility of objects and octane doesn't support it...
Or I missed something ?
mbetke
I tried Rayfire out years ago and it computed the sequence and then it was a keyframed animation. This is supported with Octane.
PURE3D Visualisierungen
HHbomb
Thanks for reply. But I meant that in rayfire, a trick is used very often to replace one object by another one : pflow particles, or specular materials. To do this, visibility of the objects are set to 1 to show and 0 to hide. Problem is that octane don't support visibility of object, so a lot of features of rayfire become useless... :-(
suvakas
It's an easy to do thing programming wise. It's just as simple as blending node's material tree with opacity (visibility 1 = zero opacity for octane and 0 = full opacity).
Probably not a priority for Karba atm. Max plugin dev. seems to be freezed for a while anyway.
Suv
HHbomb
Thanks for reply suv.
Yes it can do the trick, but visibility works per object, if I need to animate a lot of objects not in the same way, I need one material per object... :-(
suvakas
HHbomb wrote:Thanks for reply suv.
Yep. True.
Suv
Return to “Autodesk 3Ds Max”
