OctaneRender™ for Blender 1.20.2 - 2.3 beta Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Implemented automatic installator for this plugin. Now you can just run the downloaded file to install it.
  • Added new Blender space editor type: "Materials LiveDB". Getting material from LiveDB is asynchronous - it does not block user interface. You can choose object, press "Get item" button, and work with scene... When material will be downloaded - it will be set to previously choosen object in background. Blender material is created automatically by LiveDB if Object still does not have material assigned at the time of loading material from LiveDB server.
  • Added material preview feature. As OctaneServer is not able to render two sessions in parallel - if you will take the material preview rollout open, you will not be able to start live render or F12 render before material preview will be ready (it renders at 100 samples per pixel).
  • Login-password disappear from input fields now only after successful sending to the server.
  • Improved system console and on-screen feedback messages from OctaneServer.
  • Minor bug fixes...
Installation:
- Just run the installer.;)
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v2.3 beta Linux (128MB autoinstaller file)
mac3d
Hi Jimstar.
when you click livedb-material blender crash
report Blender.txt
# Blender 2.68 (sub 0), Revision: unknown
bpy.context.area.type = 'VIEW_3D' # Property
# backtrace
./blender() [0xd02fea]
/lib/x86_64-linux-gnu/libc.so.6(+0x370b0) [0x7f61770520b0]
./blender(mat_livedb_build_tree+0x75) [0xe07ff5]
./blender(draw_mat_livedb+0x77) [0xe06ca7]
./blender() [0xe04f26]
./blender(ED_region_do_draw+0x8a5) [0xf6fea5]
./blender(wm_draw_update+0x5b3) [0xd073f3]
./blender(WM_main+0x28) [0xd04348]
./blender(main+0xc11) [0xcc7171]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f617703cea5]
./blender() [0xd01b89]
thanks for all the work you do
Sorry for bad english.... :oops:
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
mac3d wrote:Hi Jimstar.
And where exactly do you click? On my Ubuntu it works OK, can you please describe a little more detailed?
matej
Thanks for the update!
Maybe its just me, bit if it would be possible could you post a "manual installation package" besides the automatic one (or a way to only extract files from the .run package)? I prefer to have control over where programs go and keep them in specific non-system locations / partitions.
cgmo.net
mac3d
When I click the icon material livedb blender crash
My system Ubuntu 13.04 64-bit
kaiwas
Thanks!
But LiveDB....
Can I get a *.zip instead *.run ?
mac3d
hello kaiwas
You run blender from usr/local/Octaneblender?
r4ytrace
I actually was so tired last night I didn't get to test 2.2 - I shall install this build tonight and see if I can get the rendering to work :).
just realised this is Linux only - I'll test 2.2 win now :)(
kaiwas
mac3d wrote:hello kaiwas
no. from / usr / local / OctaneBlender not start
Addon copied to another folder. either starts with the replacement of the executable file.
Kubuntu 12.10
matej wrote:Thanks for the update!
Try:
octane_blender_1.20.2-2.3.run --tar x
Kubuntu 12.10
It seems that you are runing your default blender with this command. From /usr/local/OctaneBlender folder type
$./blender
NOT
$blender
Return to “Blender”
