1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just copy the files from archive to root file system (into the same folder-tree as in archive). If your Linux distro has "/usr/lib64" folder instead of "/usr/lib" - copy Octane libs from "/usr/lib" archive path into this "/usr/lib64" folder.
- Run the OctaneServer as daemon:
# OctaneServer &- If you got error messages that blender needs some libBlahBlah.so library - you can run the install_deps.sh script from installed blender folder with appropriate command-line keys. It will download, compile and install all needed libraries. If you dont want to install only the needed libraries - you can install all possible using --with-all key (but be ready it may take a lot of time to download, compile and install them all).
- Fixed bug - Octane World presets were not working.
- Fixed absorption medium bug.
- Fixed scattering medium bug.
- Fixed falloff texture bug.
- Fixed metaballs bug.
- Fixed defaut "roughness" value in glossy material.
- Added Blender's own "Post Processing" rollout to "OctaneRender" mode.
- Minor bug fixes...
DOWNLOAD
Blender Octane Edition - v1.6 beta Linux (129MB archive file)
