OctaneRender™ for Blender 1.20.2 - 1.6 beta Linux [OBSOLETE]
JimStar
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
Installation:
- Just copy the files from archive to root file system (into the same folder-tree as in archive). If your Linux distro has "/usr/lib64" folder instead of "/usr/lib" - copy Octane libs from "/usr/lib" archive path into this "/usr/lib64" folder.
- Run the OctaneServer as daemon:
# OctaneServer &
- Now you can start blender.
- If you got error messages that blender needs some libBlahBlah.so library - you can run the install_deps.sh script from installed blender folder with appropriate command-line keys. It will download, compile and install all needed libraries. If you dont want to install only the needed libraries - you can install all possible using --with-all key (but be ready it may take a lot of time to download, compile and install them all).
  • Fixed bug - Octane World presets were not working.
  • Fixed absorption medium bug.
  • Fixed scattering medium bug.
  • Fixed falloff texture bug.
  • Fixed metaballs bug.
  • Fixed defaut "roughness" value in glossy material.
  • Added Blender's own "Post Processing" rollout to "OctaneRender" mode.
  • Minor bug fixes...
DOWNLOAD
Blender Octane Edition - v1.6 beta Linux (129MB archive file)
grimm
Excellent! Thanks JimStar, the absorption medium is working much better now. :)
mac3d
Hello everyone, I try and try again but I do not understand where I'm wrong with the plugin blender + octane.Ho also downloaded a sample file but I always render a black with a message waiting immagine.Why?. Please help me: (
Use translate language, sorry for bad English
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
matej
mac3d wrote:Hello everyone, I try and try again but I do not understand where I'm wrong with the plugin blender + octane.Ho also downloaded a sample file but I always render a black with a message waiting immagine.Why?. Please help me: (
Did you start the server before starting Blender?
Did you input the username & password in the fields, before starting to render (see manual)?
Do you have a Blender->Octane plugin license?
cgmo.net
mac3d
Hi Matej,
Yes i have started octaneserver and i input my username and password in the field, but i did not buy a octane plugin license for octane plugin, but i have dowloaded the octane plugin from jimstar and i would like to try it before any purchase or i have to buy it without trying ?
Thx so much for now
mib2berlin
Hi mac3d, this is not a Demo version, you need to purchase a license for this addon/plugin/server.
They announced a Demo in the news thread but nobody knows when.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
mac3d
ok,thanks mib2berlin
Synthercat
I get an "error while loading shared libraries: liboctane.so: cannot open shared object file: No such file or directory" When I go for OctaneServer &
other distros worked fine, I am trying a fresh Ubuntu 10.3-64bit
Just to make sure I placed the lib files liboctane.so and the other one, inside :
/usr/lib
/usr/lib32
/usr/lib64 (there wan't any such folder! I created it)
Why can't it find the liboctane.so?
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
JimStar
Synthercat wrote:I get an "error while loading shared libraries: liboctane.so: cannot open shared object file: No such file or directory" When I go for OctaneServer &
/usr/lib
/usr/lib32
If your system has /usr/lib and /usr/lib32 - there is no need to create /usr/lib64, as in this case /usr/lib is for 64-bit libraries.
If you have copied the libs into /usr/lib - the system should see them. But you should never place 64-bit libraries into 32-bit folder.
Synthercat
I don't know why it didn't find it but nevermind Jimstar, I will go back to other distro (DreamStudio) cause 13.04 Ubuntu run blender on turtle-speed.
Return to “Blender”
