Revit crash
didierA
hello,
I use the plugin "OctaneRender for Revit 2014 Setup 1.20a beta"
it installs correctly, but window appears:
Then the plugin can only start if I'm on a 2D view and if I do not quickly pass a 3d view, relives crash.
Where is the problem?
thank you for your help.
Revit user.
Hi Didier
The plugin saves the scene data against the "Project Browser" scene object. I suspect that on the French version of Revit the "Project Browser" has a different name. I will download and install French Revit 2014. In the meantime, could I trouble you to post a screenshot of your project browser window pls?
didierA
Hi paul,
Here is a picture of my project browser (if I understood correctly)
and also the log file Revit. (not possible .txt not allowed)
Thank you for help.
Revit user.
Thanks - it will take a while for Revit French to download. In the meantime I will upload a version which handles this situation better, and tries to get the Project Browser by the term "arborescence du project". Should be uploaded in the next hour or so. I will post here when done.
I have posted a revised version of the plugin which will assist with this issue. Pls see http://render.otoy.com/forum/viewtopic. ... 51#p149051. If the "Project Browser" is still not found (warnign message given by the plugin), pls let me know and I will install Revit French to fix the issue.
didierA
effectively, the browser is not found
Revit user.
OK - thank you. Installing French Revit now. Will have an update to you in 12hours. Sorry for the delay.
Curcis
Hi everybody, i have the same message, but all is working well. Look at the short video.
Salut Didier, que ce soit sous revit 2013 ou 2014, j'ai effectivement le même message.
Par contre cela fonctionne.
Pour lancer l'octane view port, il faut obligatoirment être sur une vue 2d.
Ensuite, on active le plugin, et on clic sur open viewport.
Il faut alors choisir non pas une vue 3d mais une vue de caméra, il n'y a que celles là qui marchent.
Je t'ai fait cette petite capture vidéo:
http://screencast.com/t/geoRBSeXb
Ou alors, je n'ai pas tout compris à ton problème. (ce ne serait pas la première fois).
A+ :D
didierA
Thank you Curci, for your solution but often Revit crash when even if I'm not fast enough in choosing the 3d view.
je suis certain que Paul va résoudre ce problème très vite.
En tout cas cela va être un vrai plaisir d'utiliser Octane avec Revit
In any case it will be a big pleasure to use with Revit Octane
Revit user.
Hi Didier - did you download and install the updated plugin? The update should stop the crash. If you are still getting a crash, pls provide details of the crash message. Also, what release of Revit or you on?
I have tried installing French Revit on 3 separate PC's now and cannot. I am re-downloading - perhaps the installer is corrupt.
One final thing....every bit of info helps me track down problems - so if you speak (type) in English, I might pick something up that help rectify the problem you are having sooner.
Return to “Autodesk Revit”
