Render Queue
- morphious2013
Any news on a render queue for Octane Plug for Poser?
This is a very big programming task, only one other person has requested it, and the benefit is less than some other enhancements I have planned, so I is not on the high priority list at the moment. If others ask for it, I can push it up the list.
- ArminBeier
I am looking for it as well.
I usually render my pictures and animations over night via queue renderer, since my pc is in full use working on them and other projects.
Now I only can do one project over night, because I can't wake up every 1-2 hours to start the next thing.
A queue renderer would be a huge help for my working speed.
I don't know anything about programming, but I thought it would simply be something like:
command > open poser file > open octane plugin > load rendertarget file > render picture/animation > done/close > open poser file...
vote +1
for higher priority
vote +1
for higher priority
OS: Win7 x64
CPU: i7-4770 @3,40GHz
Mainboard: Z87-Deluxe
GPU: 2x GTX980 Ti Hybrid
RAM: 32GB
HD: 250GB SSD
RAM: 32GB
HD: 250GB SSD
If it was simple, it would have been done alreadyI don't know anything about programming, but I thought it would simply be something like:
Having PoserPython load Poser file, run the plugin, render an animation, close the plugin, close the file, open the next file, etc will be very very difficult to do. It's not designed to do that sort of thing, and neither is the plugin.
This type of functionality should be supported with new Octane Standalone version. At some point we will be able to export an animation from Poser to an OCS file, and you could batch up the OCS files to render overnight. Standalone also has LUA scripting which you could use to do this too.
- ArminBeier
It was worth a tryface_off wrote: If it was simple, it would have been done already![]()
Is it possible allready with the standalone, or do you mean the next release (1.5) with "the new standalone"?
OS: Win7 x64
RAM: 32GB
HD: 250GB SSD
RAM: 32GB
HD: 250GB SSD
The 1.29 version will already export a frame to an OCS file - and Standalone can be controlled via LUA scripting (http://render.otoy.com/forum/viewforum.php?f=73), so it's probably possible for something with some good LUA skils to write a batch importer/render process from Octane Standalone. I could easily enhance the Poser plugin to write an OCS file for each animation frame is this was available.
- ThetaGraphics
- Contact:
This method would only work within one scene file, but if you are needing several different camera angles of the same scene, you can set up an animation with each frame being a particular camaera angle/position. You would need to use the same camera for each shot, but it would allow you to render them all in one go.
OctaneRender - DAZ Plugin
Win 10 64-bit | Intel 17-5930K 3.5GHz| RTX 3090 and GTX 1080 | 64GB RAM
- spartan00j
- Contact:
so is there a way to batch render poser scene's all at once yet.
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
Export all the scenes you want to render to ORBX or OCS, and then render in Octane Standalone. You may need to use some LUA script to load each OCS, render and save the result.so is there a way to batch render poser scene's all at once yet.
