OctaneRender® for Maya® v1.16c beta [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
  • Now materials are animated in "Movable proxy" animation mode too.
  • Some 1.16 engine fixes...
  • Minor plugin fixes...
DOWNLOAD
OctaneRender for Maya v1.16c beta (35.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
danimatrix
hi JimStar when I open the scene, I get FATAL ERROR!!!
renmaxhb
Thanks,JimStar,greatwork!
arh-osa
The same issue that danimatrix reported, when I open a scene made in previous version.
SketchUp Pro 8/ Maya 2012 / W7 64bit / Intel i7 870 / 8GB / 2*GeForce gtx 680 4GB
Can somebody give me the scene where you have this error?
TBFX
Hi JimStar,
Yes same issue for me. Here are some crash logs and a sample scene that crashes v1.16c
The crashes happen for me when I start a render, either IPR or standard they both cause the crash.
T.
MayaCrashLogs_130604.zip
(818.26 KiB) Downloaded 190 times
Thank you!
renmaxhb
Renderer use vedio memory 900M when I run IPR,
renderer use vedio memdry 1800m when I run batchrender.
The scences can run IPR but can't run batchrender.
renmaxhb
Like this
TBFX
renmaxhb wrote:Renderer use vedio memory 900M when I run IPR,
Is the animation mode set to Movable proxies for your batch render? If it is set to Full then any instances will get loaded as part of the global mesh taking up a lot more VRAM.
T.
Return to “Autodesk Maya”
