Blurry face
bpzen
Hi guys,
I did a few full body shots, it seems the face on these for the avatar is a bit blurry, I have Costic set to 1 then 0 that did not change much and I am clicking AFI then the face area on the view port. Any thoughts on why this may be happening?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
Sounds like it is just out of focus. Click the focus-pick button, then click on the figures head and it should bring that into focus. Or drop your aperture down to something small like 0.1.
bpzen
Yea I agree Paul, I should be clicking on the figures head in teh octane render view port correct?
yes, click on the viewport. you should see the focal distance change in the octane settngs tree.
morphious2013
I have the same problem. Auto Focus is not working. I have it enabled, open octane view, and click on an area, and the focus stays the same. Is there a recomended setting in Poser camera that will help? Thanks.
To see "focus picking" in action......
- set the camera aperture to 20 (so everything will be out of focus exact geometry at the very close distances to the focus point)
- Activate the A/F button on the Viewport
- Click on a part of the figure
- Once clicked, the focalDepth will automatically be put in the "camera" pin for "focalDepth", and "autofocus" will be Disabled
If you click on part of the scene where there is no geometry, the focalDepth will not be updated.
morphious2013
Ahhh, so you have to select AF in the Octane Panel AND in the render window.
You don't have to set it in the Settings window - just activate the A/F button in the Viewport window.
morphious2013
Then why is there a button in the settings window that lights up when selected if not needed?
If you are referring to the Eye button on the Setup window - that is not for focus picking. Mouse over it for help text, or read the manual section at - http://render.otoy.com/manuals/Poser/?page_id=52.
Return to “Poser”
