Transparent background
bpzen
Hi all
Can someone point me in the right direction to render just teh actor with out a background in Octane, transparent background?
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
There are a few elements to this.....depending on if you want the ground shadows to render or not. But in summary, tick the "kernel"-"alphachannel". The Poser plugin shows some noise between the rendered objects and the alpha background, but is saves fine. Just save and then merge with your background in Photoshop/GIMP. A future versions of the plugin will allow you to load the background image into the plugin so it renders directly onto it.
If you want ground shadows to render, the process is more complex, and there are a number of threads in this forum about it.
bpzen
thank you
Return to “Poser”
