TEST DRIVE ABU DHABI : Storyboard part 4 released
niuq.cam
Hello
The Part 4 of Test Drive A.D. is complete.
Duration : 1.15 Generic off.
The task is Huge but hearts are hardworking.
Niuq and Vonc are in da House. :twisted:
For those who missed the start of the saga, a text explanation may be helpful:
- 32-44: The Murcielago expecting a play companion when suddenly an eagle appears from the road.
- 35-39: Murcielago is catching up fast in manhandling than usual motorization.
- 40-43: No way to get overtake for Gallardo...
- 44-46: Nor longer, the Murcielago opens its wings of hell, it means it's going to speed up.
- 46: A pure slow motion, Murcielago overtake without giving him a chance.
- 47-49: Well, it goes to something else and still speed up again and again.
- 50-52: Furious downshift with demonic chants. The party seems to have stopped.
To be continued ... :arrow:
Now a rereading of the storyboard (Parts 1 & 2) is necessary as some things must change.
To name a few:
- New Dresses and carshaders for the Gallardo.
- New more realistic atmospheres.
- Optimized some framing and movement, the sound design has evolved too.
Go BANZAI !!!! :twisted:
Niuq
wow, great, wonderful job, you are near to finish :D
approximately, what is the time per frame?
Mackraft
OMG this is real? :shock:
The most beautiful pictures I've ever seen.
You have a trick to use Octane to create atmospheres and situations. It's impressive and rare.
I look forward to your film.
Fantastic desert !!!
nehale
Wow your taking C4d Vfx to another level!
Regards
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
niuq.cam
Thank you so much nehale & mackraft for your kind comments. :D
bepeg4d wrote:wow, great, wonderful job, you are near to finish :D
For this resolution at which I work commonly (1024 x 430), 3 minutes approximately.
But for the final calculation in high resolution,
I will make a great cleaning of polygons and textures not visible.
I always use your solution to not having disconnected nodes (underground^^)
Best regards.
Niuq
A little bit higher resolution
attusind
great job!
very impressive :o
Asus Z97-WS | i7 4790k 4.0 Ghz | 32 GB ram | Quadro 600 | 3x GTX 980| Win 7 64 bit | nvidia 344.75 | Cinema 4D R16 | OctaneRender™ for Cinema 4D 2.23.2 RC3
http://www.attu.it
Refracty
good work buddy. Can't wait to see the beatiful work in motion.
bicket
waouw ! :shock:
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
ROUBAL
@niuq-cam : very impressive work !
What is the problem with disconnected nodes ?
Do you mean that you put models under the ground mesh to hide them without loosing materials ? I used this method in the past, but the best solution imho is to save all important models as macros. It allows to delete them and reload at will.
I am not sure, but disconnected nodes seem to be counted in System RAM, but not on GPU VRAM.
atome451
Super !
:D
Win10 64bits | 3x 980 + 2x 670 + 1060 | Cubix XPander + network | Core i7 3600 MHz | 32GB | 1300w PSU
Sorry for my bad english...
