Live update when using 3D mouse
cfrank78
I noticed, that when i use my 3d mouse (space pilot pro), the live update does not work. Also the "update geometry" feature does not work in most cases, but thats not a 3d mouse problem.
Am i doing something wrong?
When i use the C4D controls, the live update works without any problems, but when i use my 3d mouse, the render window just updates, when i release the mouse. This is a big issue for my 3d Workflow.
Am i doing something wrong, or is this a bug?
Kind regards Chris
PS: i used the latest beta release! 0.49 (SDK 1.14) with C4D R14 on WIN 7 X64.
Did you see video which show geometry updates? To point objects who are checked for updates need a octane objecttag. Also there is a geometry channel number. 0 is for static meshes. That's will be unchecked. If you give bigger numbers you''ll aasign to update channel.
Which 3d mouse? I have not a device like that
cfrank78
Hello Aokar.
Just purchased and did not see all videos. I just tried 0.3.4 before and there the geometry update worked. Can you please post a link to that special video? Thanks!
I use a 3dconnexion space pilot pro. I also tried with the space navigator (i have both). Same with both. As soon as i release the 3d mouse, the live window restarts to render again, but while i move my 3d mouse, i can not see anything. This is really a huge problem, cause i am used to it, from my 3ds max workflow, where i do "live" animations with the fly through szene, key setting, which is much more accurate, than in the modelling window itself!
Thanks for your fast answer!
EDIT: I found the Video - update is working fine now. Thank you. Watching all Vids right now. 3D Mouse Problem exits further!
Kind regards Chris!
cfrank78 wrote:Hello Aokar.
Kind regards Chris!
Cool, nice to see you there. I'm going to check this issue about 3d mouse asap. Actually i have'nt.
I have released Beta 0.49 and a fix Beta 0.50. This is in c4d section. Please check plugin announcement threads..
Also Geometry update functions re-writed. And nearly perfect except instance handling.
Enjoy it
http://render.otoy.com/forum/viewtopic.php?f=30&t=31962
my vimeo:
https://vimeo.com/user5491763/videos
cfrank78
Enjoy it
Hi Aoktar!
I allready use 0.49 - 0.50 i could not find, but updating geometry works pretty stable here in my first tests. just did not knew, that i had to put an object id to the models.
I made a video for your convenience to see what the "bug" is. In the first part of the video, i move with the c4d standart navigation tools, in the second part, i used my 3d mouse. you can see the difference very clearly i think.
The video is not "listed" and only for you guys,who see this link here, visible. I hope it helps you.
Kind regards Chris!
