Can anyone suggest some software that facilitates the creation of attractive rendered floor plans for residential use?
The various web options I have seen (including Autodesk Homestyleronly produce very flat results. I am looking for something with shadow, some life.
Rendered Floor Plans
hi there.
plan with shadow? isn't a plan..basically a line drawing on flat surface? where the... are shadows? =) kidding =p
if You want to have 3d cuts, just extrude Your walls in chossen 3d package, setup a camera from top, choose nice lighting & do some renders in octane =) 'cos it will be open scene render times shoudn't be cosmic for basic materials =)
this do involve some labpur, but a leas You could have nice output =)
Archicad 17 has new feature floorplan with shadows
http://www.youtube.com/watch?v=KZXJB7UeY9g
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
I would use splines for it. fast to layout, can be extruded or thickened. I did lots of plans this way. Mostly the splines from DWG files could be used or even cleaned up quickly.
PURE3D Visualisierungen
- Jaberwocky
Pullakk
You mean something like these.
This is Sketchup - Free Version
I didnt explain myself well.
I meant Furnished Plans...something like this:
https://www.dropbox.com/sh/aabisbjr2jhwbh0/mtXdtVDvBa
piotr
piotr
i7 2600K (P8P67-Pro), 8GB, GTX580 3GB
I used to export technical blakc/wite linedrawing to tif (or jpg) and do the texture filling in photopaint (or photoshop), and also shadows. First time is most work, second time you can copy a lot stuff from previous floorplans.
Greetings,
Greetings,
So anyway, I collected some furniture from previous jobs, applied some basic materials and ended up doing it in 3d. rendered with Octane for a couple of minutes.
Not too badPullakk wrote:So anyway, I collected some furniture from previous jobs, applied some basic materials and ended up doing it in 3d. rendered with Octane for a couple of minutes.
Probably you have less controle on the looks of texture compared to postproduction in photoshop but this looks like a big timesaver
Did you use ortho or camera on large distance and small fov?
