Hello
I am trying to figure out how i can use a material in the Live DB but scale the texture down so it fits the scene. Example, I am using a floor tile, when i load the material on the poser prop the tile look HUGE, iv messed with all the setting that seem to indicate they would adjust scale - but cant figure out if or what dial would do the trick to reduce the visual size of the tile.
thanks
Material Scale ?
- KleanZlate
Adjust the scale value under the image nodes. Note that higher values mean smaller images. You might have to adjust several images (diffuse, bump etc.)
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
