Material Scale ?
bpzen
Hello
I am trying to figure out how i can use a material in the Live DB but scale the texture down so it fits the scene. Example, I am using a floor tile, when i load the material on the poser prop the tile look HUGE, iv messed with all the setting that seem to indicate they would adjust scale - but cant figure out if or what dial would do the trick to reduce the visual size of the tile.
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
KleanZlate
Adjust the scale value under the image nodes. Note that higher values mean smaller images. You might have to adjust several images (diffuse, bump etc.)
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
bpzen
perfect thank you
Return to “Poser”
