Crazy feature request :)
sqjam
Please, combine diffuse and glossy shader.
If specular=0 then shader=diffuse, if >0 then specular.
Or add SSS channel to glossy shader.
This is made workflow and tuning of shaders more easy.
Thanks.
interesting request, but you forgot the emission channel of the diffuse material ;)
for me, the diffuse material is good only for emission, absolutly not good for sss. if you want a glossy material with sss simply switch to specular material with 0 or low transmission, it's perfect not only for trasparent materials and it's extremly flexible ;)
kavorka
bepeg4d wrote:interesting request, but you forgot the emission channel of the diffuse material ;)
I've used diffuse material with SSS for things like a silicone watch band that scatters a little. Spectral would not work in this case.
So, I think the 3 materials have their uses.
if you start using a glossy, but end up just wanting diffuse, just change the node type.
sqjam
If I need glossy reflection and sss I should use mixed materials - it is not comfortable. This is just workflow - not internal shader logic.
you don't need a mix material, the specular materia has all the necessary channels for glossy reflection, just make it solid ;)
here is an example of skin shader made only with one specular material node:
https://vimeo.com/64817671
[vimeo]http://www.vimeo.com/64817671[/vimeo]
sqjam
bepeg4d wrote:you don't need a mix material, the specular materia has all the necessary channels for glossy reflection, just make it solid ;)
WOW! Thanks, I try.
Show setting please.
sqjam
bepeg4d wrote:hi, please refer to this discussion for details ;)
http://render.otoy.com/forum/viewtopic. ... 29#p136329
Thanks!
sqjam
@bepeg4d
Your shader work in 1.13 and don't work in 1.10.
sqjam wrote:@bepeg4d
it can work only from 1.11 and above ;)
in 1.11 the sss system was completely rewritten and the new "fake shadow" option was added to the specular material. without this option no magic could happen :)
