OBJ. Export
timati
Hello. I have a little problem. I export car to obj. from max with many details but when I open it in octanedemo I have only one object and I can’t assign a material to the different parts:( Can you help me fix this problem? Thanks
radiance
Please look in the resources forum, there's a thread on top called 'OBJ export options...' which contains screenshots on how to configure 3ds max to export correctly to OBJ octane needs.
also, make sure you don't have spaces in your paths. (although this should be solved by now with 2.2)
Radiance
hmk
Check this thread, http://www.refractivesoftware.com/forum ... =23&t=3070 hope it will help.
http://www.OctanePowerTools.com
Octane Render Power Tools, Animation Tools for Octane Render
facebook | YouTube
Intel Core i7 920 @ 2.67GHz - RAM 12.0 GB
Asus P6T7 WS SuperComputer GTX 480
timati
Thanks, but still have a problem,just don't know what to do... :(
radiance
I'm sorry but we can't help you without more information.
Please provide us with whatever is helpfull in determining the problem, like a simple test scene, screenshot of your export options etc...
Radiance
timati
Hello
there are 3 objects in the scene,but octane see's only one. Where is my mistake?Thanks
octane
octane
export settings
export settings
This is my scene:)
This is my scene:)
lixai
at this time, octane supports only one mesh at one time, but this mesh can contain many objects and many materials (that you can assign from max in your case) also you can not move objects in octane, you have to do this in your host app
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
radiance
Does it export an MTL file with material definitions in the same directory as the OBJ file ?
did you assign materials per object in max prior to exporting ?
Radiance
timati
First question-yes
Second-no
timati
Cool!!! Thank you so much :oops:
