Problem with light
Hi there. im working on interior viz with octane. This is for me first scene with it. Right now i have problem with noise from light. in the attachment a show light source, which produce a lot noise and flicker points. every other light source are good, even it is the same material.... Light source: plane 50x50mm, about 10mm above ground plane. material blackbody with RGB color, 25 multiply. octane 1.10. thanks for answer
geforce 560gtx, Phenom 965, 8GB
- gabrielefx
the light is too much small
try to use pmc kernel or pt with caustic blur set to 0,5 or 1
and hot pixel remove to 0,75 or 0,5
the fireflies comes from the pool, turn off sequentially all the lights to see what happens.
