wip interiors
I found out it's easier to model a living room you're inside of.. tried doing the textures with my DSLR
3dmax, zbrush, UE
//Behance profile //BOONAR
Nice ones, I like the second one more though. Both needs more accessories, maybe some home plants and a carpet will give some nice touch too.
http://www.OctanePowerTools.com
Octane Render Power Tools, Animation Tools for Octane Render
facebook | YouTube
Intel Core i7 920 @ 2.67GHz - RAM 12.0 GB
Asus P6T7 WS SuperComputer GTX 480
facebook | YouTube
I'm also trying to do an interior, but i seem to have trouble with getting enough light inside.
With pathtracing it takes ages to render and i have an enormous contrast between the light inside and outside.
What are you using? it seems to work perfectly
Antec 300 Casing/Windows 7 ultimate 64/i7 920/ ASUS p6T/ 6GB RAM/ Sparkle GTX470 1.2GB & Asus GeForce 8800GTs 512mb
had the same problem, if you take a look everyone's windows are too bright I guess..Mateuet wrote:I'm also trying to do an interior, but i seem to have trouble with getting enough light inside.
Well it's a combination of things, first of all there is no glass in the windows, another thing is that I have openings behind and on the right, that's where the doors are so it has enough openings.. for the second one I used photomatix to tonemap the image like you would an HDR image.. seems to work ok - but you need to save 3 or 5 pictures in different exposures, take one with the window exposed correctly another with interior and one with everything as balanced as you can get, well that's how you would do it with a real camera.
Anyway it is a bit difficult to get the contrast between outside and inside right so don't go making a render close to a window
I wander if we could get that HDR technique on the fly inside of octane..
Well I really try to treat the octane renders as if they were pictures since I also do photography (amateur for now), it seems to help when you take tens of thousands of pictures and look at the result afterward, it just makes more sense
3dmax, zbrush, UE
Seems pretty complicated. But i had the same problem in Mental ray also. Cameras don't lie.
What i did back then was to lower the energy from the sun and rise the exp. maybe it works.
It's funny though that with direct lighting the sun came in much better than with pathtracing...I'll post the renders tonight.
