OctaneRender™ Standalone 1.13
roeland
Hi all,
Here comes the next release of our development cycle towards 1.20, with mainly fixes for bugs reported for 1.12.
Changes since 1.12
  • Added control to make the bokeh in out of focus areas less smooth.
  • Fixed transparent patches on glossy materials with bump or normal mapping.
  • Fixed subsurface scattering for diffuse materials.
  • Updates applied while the renderer is paused are applied after resuming the renderer.
  • Fixed render update after reloading any image.
  • Updated the look of the node graph editor and fixed right-clicking on nodes.
  • Fixed issues with the background image dialog, and added support for reading HDR background images.
  • The node graph editor can be scrolled with the mouse wheel when holding down Control. There is a setting to choose the default action.
  • Fixed possible lockup when using a 3D mouse while rendering a large image.
Download:
Windows
ZIP archives:
- 64-bit32-bit
MacOS X
DMG image:
- 32-bit and 64-bit
Linux
tar.gz archive:
- 64-bit
Happy rendering,
Your OTOY NZ Team
pixelrush
Neato! Will try this out right away. Thanks guys :)
I notice with pmc and an hdr in the background when you rotate the view the hdr shows through the mesh for a couple of seconds and fades out. Is this as expected? I was using a simple hdr from the demo suite.
Using the new sun model the sun colour changes abruptly from yellow to red when camera/saturation slider gets to 2.24?
I think this will be related to a similar change I reported a while ago in the old model?.
Octane v1.55
abstrax
pixelrush wrote:Neato! Will try this out right away. Thanks guys :)
Yes, that's expected. For those pixels where the background shows through, no samples are available yet.
pixelrush
In Camera Node Inspector fov and scale appear to do the same thing. Is this correct? I guess scale is really intended to be for orthographic?
Octane v1.55
abstrax
pixelrush wrote:In Camera fov and scale appear to do the same thing. Is this correct? I guess scale is really intended to be for orthographic?
Yes and yes.
pixelrush
hmmm ok well perhaps the other should be grayed out then they aren't the active mode ;)
edit: although I see the sliders are linked.. :roll: slightly confusing or maybe its just me
...digging around for stuff tonight... :P
wups just had a black screen :shock: - Nvidia driver issue - never had that before :?
not sure what caused that.
:idea: might have been a bloody windows driver update! AAARRGGHH! :arrow: :evil:
edit yup effing MS! 311.06... ok so uninstall and go back to my modded quadro :|
Octane v1.55
Aaaaahole
Thanks team
Win7 64 | i7 870 @ 3.2GHZ | GTX 780 3GB | 16GB | Phantom Scatter |
Refracty
thank you
Jaybee
Excellent, thanks!
Win 7 x64 | 1 x EVGA GTX680 Classified & 1 x Quadro FX1800 (display) | i7 920 o/c 3.04Ghz | P6TD Deluxe | 24GB | AX860 PSU
Jaberwocky
Thanks for the speedy update
Cheers
Jaba
