Odd delete behavior
Moderator: BK
Sighman
I had the node editor open and tried to delete a node using the delete key. Instead of deleting the node it deleted the selected figure in DS. Did this a couple of times before I got into the habit of using the right click menu to delete. Just thought you should know.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
t_3
Sighman wrote:I had the node editor open and tried to delete a node using the delete key. Instead of deleting the node it deleted the selected figure in DS. Did this a couple of times before I got into the habit of using the right click menu to delete. Just thought you should know.
confirmed.
from my pov its a bit questionable design of ds - it reads keys bevore any other application. means keys not explicitly captured by another window/pane will always do whatever their main function in ds is. if you select a node an press delete in the viewport, it gets deleted not because the plugin handles it, but because still ds reads the key press.
i agree, to keep at least the delete key from doing this would be a pretty good idea ;)
i will map the delete key to specific functions of the plugin (mat tab = delete material, nge = delete node, viewport = same behavior, but probably managed by the plugin itself).
other useful keys: post them here :)
The obvious is that which is never seen until someone expresses it simply
Tugpsx
Keep in mind one of the great things about using the plugin with Daz Studio is that you now have an undelete/undo option that does not exist in the standalone. :twisted:
t_3
Tugpsx wrote:Keep in mind one of the great things about using the plugin with Daz Studio is that you now have an undelete/undo option that does not exist in the standalone. :twisted:
but, um, only for any studio related type of changes :oops:
changing octane parameters or material changes, node deletions/inserts/connection changes, whatever, still has no undo (or even redo). it is to some extent prepared, but still needs a lot work to get finally implemented. it though might happen that the ds plugin will have it before the standalone ;)
Return to “DAZ Studio”
