A Special Please
treddie
Could Otoy PLEASE seriously consider putting a "Lock Settings" feature in Octane? This has been one of those "danger" areas where all it takes is an accidental move of the mousewheel over the Node Inspector and you're screwed. Especially if the render has been going a long time. All that work is just gone. It just happened to me again, and I lost 10 hours of rendering.
It's a simple addition...Wouldn't take but an afternoon to code and debug it and it's REALLY important.
Win7 | Geforce TitanX w/ 12Gb | Geforce GTX-560 w/ 2Gb | 6-Core 3.5GHz | 32Gb | Cinema4D w RipTide Importer and OctaneExporter Plugs.
This feature is built into the Poser, ArchiCAD and Revit plugins.
ROUBAL
+1 ! This kind of accident already occured to me.
t_3
face_off wrote:This feature is built into the Poser, ArchiCAD and Revit plugins.
and daz studio too, to note one more ;)
kavorka
for now, I always turn off the option to render the material when you click on it. These options are in the top left of the node inspector.
treddie
I use Standalone, so I don't have that feature. :(
hi treddie,
if i remember well, you have also c4d in your working pipeline. if yes, maybe you might take in count the new c4d integrated plugin :roll:
If you launch a render in the picture viewer, any changes can't have any effect to the render already started, and you also have the undo option ;)
matej
Disable param slider movement with the mouse wheel, already...
It's very bad GUI design for the mouse wheel to scroll content and at the same time move sliders. People are not using this "feature" anyway, exactly because of the reasons OP pointed out.
cgmo.net
slimSpencer
+1
maybe like this: when over ~200? samples are rendered, there is a confirmation-dialogue before re-rendering starts because of (accidential) parameter-change.
br
E3-1230v3 | 8G | gtx 750 Ti | win 8.1 | blender + octane standalone
treddie
I should I guess. I'm just so used to using the standalone version. Autism, maybe! :)
ANYTHING to stop an auto-rerender in its tracks would be nice.
Too many programs have it these days and its more of a gimmick than anything else. A lot of programs try to put so many "conveniences" in a program those conveniences begin to overlap and produce inconvenient results.
