Lightwave 3D Plugin v0.1
holocube
Comes with two .obj exporters - you can switch between the two inside the Octane Exporter GUI.
  • "Lightwave HC OBJ Exporter" is Lightwave Layout internal obj writer only available in Lightwave HC (build 2013 or later)
  • "Octane OBJ Export" is written by me and windows only. For Lightwave 9 or later.
Please check the readme inside for more details and differences between the two.
!Please make sure you read both the offical manual on Plugin<->Octane workflow and the readme.txt inside this package before using this plugin.
If you have any issues please give me information what your export settings are and what you're exporting. You can reach me on skype 'walfridson' or at my mail if you want faster contact or sending me files.
LWOctane_v01c.zip
(251.99 KiB) Downloaded 1114 times
LWOctane_v01b.zip
(262.81 KiB) Downloaded 1201 times
GTX260 Seven 64bit
I'm Superfrog
holocube
* POI item list now displays all items in scene.
GTX260 Seven 64bit
I'm Superfrog
geo_n
I'm testing the plugin.
It seems that the object exporter is writing uv that are automatically healed seams? The obj files uv is showing this so in octane there are errors. I tried all modes in layout write uv normal but still getting errors with the seams.
lwo file
obj file from lw 9.6 exporter - healed uvs.
geo_n
This is blender obj export loaded in modeller. UV is ok.
geo_n
The lightwave hc obj exporter has better uv but I don't know why but I can't get octane to read the uv info from the obj file unless I specify no to export point selection as groups, which messes the uv again. The hc version is fast though.
Hc exporter - uv is good, but octane can't read the uv info
octane hc exporter
holocube
could you share the object?
GTX260 Seven 64bit
I'm Superfrog
geo_n
Ok will upload them and send you pm.
Here's also something I discovered with the lightwave object exporter. Multiple uv are combined and healed.
uv1
uv2
obj from the exporter has uvs combined and healed. the combined uv probably is not a problem but the seams get messy same as the triceratops.
geo_n
Does the plugin support bone and mdd animation? My test doesn't animate using both. But translation, rotation of object and camera animation is ok.
For doing arvhiviz unweld all points in modeller so uv won't get healed when exported. Not really a fix but for testing its ok.
holocube
Thanks for the object.
Changed how it writes UV, please try again.
Bone & mdd should work fine but I added a check box in the lw export settings tab - force obj write. I rendered an object being deformed by a bone and worked fine.
GTX260 Seven 64bit
I'm Superfrog
geo_n
Ok did new test. UV issue is fixed. And mdd animations work if force obj animation is checked. A bit slow than no check but for mdd this is the only way.
Now I tried new lw scene, new octane scene and first time I have two layers in layout. Triceratops mdd animation and a ground plane. Exporting out from layout the two objects fuse together.
octane with mesh error
obj from layout mesh is merged
screengrab of layout. 2 separate layers, triceratops, green ground
Return to “Lightwave 3D”
