OctaneRender™ Standalone 1.11
abstrax
Hi all,
Here comes the first release of a new development cycle towards 1.20.
There have been some major changes in Octane which cause it to run a lot slower on pre-Fermi GPUs
(with compute model < 2.0). PMC and the matte material still don't work on these GPUs either. We
also have major issues building the CUDA kernels for these old GPUs, which is why we had to remove
the support for compute model 1.0. It's is becoming more and more likely that we have to discontinue
support for pre-Fermi GPUs in the not too distant future.
Changes since 1.10:
  • Added architectural glass as option "fake_shadows" in the specular material node
  • Improved direct light calculation in SSS materials - as a side effect volumetric noises don't work anymore
  • Improved accuracy of intersecting volumes with different IORs
  • New multi-threaded mesh compilation with better render performance and lower memory usage during compilation (/voxelization)
  • New dirt texture node
  • New panoramic camera node
  • New wire-frame mode in the deep channel kernel
  • New PMC kernel option "parallelism" that reduces the number of samples that are investigated in parallel, to make caustics appear earlier at the expense of some performance
  • Improved daylight system
  • Black edges in glossy materials are fixed
  • Surfaces with a matte material hiding all objects behind, but are visible indirectly
  • Improved combining of noisy multi-GPU results, which resulted in too dark images in the past
  • Several bug fixes in the new OBJ parser
  • Bug fixes in the render framework
  • Default caustic blur in render kernels is now 0.01
Download:
Windows (updated on 27.2.2013, 0:50 UTC):
ZIP archives:
- 64-bit32-bit
MacOS X (updated on 27.2.2013, 20:40 UTC):
DMG image:
- 32-bit and 64-bit
Linux (updated on 27.2.2013, 20:40 UTC):
tar.gz archive:
- 64-bit
Happy rendering :)
Your OTOY NZ Team
Reason: Updated all binaries to fix a render issue and provide a missing .dll; Updated Linux and Mac builds to include the dirt texture node
JJTTBB
Looks great!!! Thank you!
AutoCAD,Revit Architecture, Max Design (all 2012) , Moi3D,Maxwell Render,Octane Render
Intel i7-8Gb RAM - Win7x64 - GTX550Ti
PeterCGS
Wow! Great release. I see a slight longer rendertime compared to me v1.10 setp, but the compilation/voxelation stage makes up for it by quite a margin :) Great work team!
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
Vanya
Thank you! :o
100% :lol: Heisenberg, nice :D
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
OctaneRender® for 3ds max®
Aaaaahole
Thanks team - yay dirt texture
Win7 64 | i7 870 @ 3.2GHZ | GTX 780 3GB | 16GB | Phantom Scatter |
Cronicash
Chur fallas!
EVGA sr2 2x x5650 12c/24t| 64Gbddr3 1600mhz | 4x gtx580 3gb on h20|4x 128x corsair ssd | 2x Strider 1500watt + 500watt |swiftech Blocks ,3x quad rads + dual rad (two loops)||8Tb|Laptop:Dell XPS 1730| 4Gb| 2x 9800GTX sli
Portfolio/blog
Dmitry Lebedeff
yyeeeeaaaahhhhh :twisted:
cfrank78
It is so great! Thank you!
But i cannot find the fog System, which you guys said will be implemented in 1.11! Or do i miss it?
Chris!
Newman
Great job! :)
Sorry for my bad English
Win 8 PRO x64/ Core i7 950 / 16gb RAM / GTX 460/ GTX670/
Force44
thanks)
http://www.picfad.com
Core i7 2600k @4.2 Ghz | Asus Maxiumus V Extream | 3 x GTX 590 watercooled| Crucial Ballistic Sport 32gb | Crucial m4 64gb | Seasonic Gold 1250 | Octane render| Skethcup Pro 2013 | Blender 2.68
