This is how I make Hamburgers!
marcobaccioli
Working on a series of 3D images (one hundred) for a client, food is one of the topics I have to cover :)
ps: I know, there are many details that I have left behind, but I had to move on to complete the remaining images...
Windows 7 64 bit | Geforrce 460 GTX | Intel Core i7 | 16 GB | Blender 2.5 | 3DS MAX Design2013 | Octane 1.50
http://artdesignstudio.dunked.com
@marcoartdesign
Rickky
seems more like rubber or plastic. Not tasteful :?
t_3
i'd like to raise a thumb here!
being one of hundred images it hasn't to be an ultra-realistic masterpiece, but decent and in first place quickly done. and if it serves the clients needs, it is just as good as it needs to be :)
The obvious is that which is never seen until someone expresses it simply
jmfowler
the bun texture looks blurry - it needs to be sharper, also the bread looks like plastic.
marcobaccioli
Thanks everyone for your feedback.. They all make sense and you are right about the plastic look... In fact, before delivering the 100 files, I'll tweak the textures settings, I guess the bread need some work with specularity&roughness values..
However t_3 is right about the fact that this is one of a hundred and I just can't spend too much time on each image..
These are other images I am delivering, as you see, some looks better, some worse ... :(
@marcoartdesign
Vanya
marcobaccioli wrote:Working on a series of 3D images (one hundred) for a client, food is one of the topics I have to cover :)
mayonnaise, ketchup?
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
OctaneRender® for 3ds max®
mbetke
It is a difficult topic with food. You would need tons of photos to make them a texture or use 1-2-3 Catch to make a series of photos and let the software convert it to a 3d model. Or you would need to model lots of small details to get a 100% look.
also turbosquid models or evermotion could help with lots of models.
If you can get away with this look its okay. Client decides. ;)
PURE3D Visualisierungen
kavorka
For the office, it looks weird just being over white with no shadows. Try making the floor a matte material and compositing.
Sometimes I will render one like that, real quick, then do another with the matte shadows (you can do a clay render so it's faster and you won't need as many samples) so I can toggle the shadows off in Photoshop if I want.
marcobaccioli
Thanks Kavorka, but the client wants PNG 24 images with transparent background
@marcoartdesign
kavorka
marcobaccioli wrote:Thanks Kavorka, but the client wants PNG 24 images with transparent background
You can render the matte shadows with the transparent background.
set the floor material as matte then check off keep environment in the kernel.
