I would like if possible that you change the RGB values from 0 to 255 like all other software. currently it is not practical.
see the attached picture.
I guess that would not be the only one wanting this change.
Thank you for the answers users
RGB 0 to 255 please!!!!!!!!!
- Elvissuperstar007
- Contact:
+1
I agree, this is more user friendly.
What I do now is get the hex code from Photoshop and place it in Octane (this might not help you for what you are doing, obviously).
All others without Houdini, Maya, Modo, Nuke, Softimage.
Also the obj file format uses 0.0 - 1.0 values...
face
face
http://vimeo.com/user2509578
... and going with 8bit rgb values would limit the color space also.face wrote:All others without Houdini, Maya, Modo, Nuke, Softimage.
face
still would be an useful alternative input method.
@Interface: did you know, that RRGGBB values are only approximations for the real RAL colors?
octane - in theory - has the capability to render them much more closely to their real world appearance, if only there was some easy way to calculate the numbers. i once found a page that somehow does such a calculation: http://www.brucelindbloom.com/index.htm ... cHelp.html - it allows you to input the lab color codes of a RAL color, but i never found out what conversion settings would be needed to get the correct decimal rgb representation out of it...
+1
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
OctaneRender® for 3ds max®
Why fiddling around with 8bit RGB if there was a possibility to enter LAB-Values that octane translates via colormanagement into the target colorspace (srgb for now)?
+1 for LAB as color input and support for alternative colorspaces.
Rendersystem: Intel i7-3770K, 16GB RAM, 256GB SSD, 2x GTX 660TI-OC / 2GB, win7x64 -> OctaneBenchmark 5.36Ms/sec (OR V1.02)
- Interfaces
T3
I am a draftsman, I use autocad in this software there are equivalences RGB RAL CLASSIC, I can provide it if you want!
cheers
cheers
- LudovicRouy
- Contact:
Another usefull node would be a fonction or math node like multiply, divide substract... working with Float and integer input
