Octane Sketchup Exporter Beta t [superseded]
TIG
Here is beta.t
Octane_1022t.zip
(271.94 KiB) Downloaded 579 times
This version has the dialog's slider js and images "hard-coded" and no longer requires an Internet connection to retrieve widgets etc [a 'tigra' slider replaces the earlier 'yui' one]. Apart from a slightly different slider appearance, you should not notice anything significant: hopefully some of you who were experiencing js error messages should no longer get these...
All users should update to new this version.
Feedback please
EDIT: The ZIP is updated with a README update for 'sliders' to match Help PDF - no other substantive changes :roll:
EDIT 2: The ZIP is updated with a README with more clarity about unzipping files on a Mac and keeping the sub-folder structure - The Help PDF has corresponding changes too... Again the core code is not altered. :geek:
TIG
radiance
thanks, i'll run some more tests today and also on the mac here.
I also asked roen to take a look at it.
Radiance
ameier
Hi TIG,
what ever you have changed.....now the glitches are gone. Nice work !
Big Thx for your hard Work !!!!
P.s.: Samples would be post later !
Intel(R) Core (TM) i7 Cpu 3770k, 32 GB RAM, 1x 670 GTX; Windows 8 64bit Pro.
Cuda Driver + OctaneRender V1.10 + Octane Sketchup Plugin
Burkhard
Any reason why the loader.rb is inside the octane folder?
Do we have to put the whole single files into the plugins folder?
cu Burkhard
MacPro Quad * 8Gig RAM * GTX 285 Mac Edition ( delete two GT120 to make it run with octane! ) * Snow Leopard 10.6
TIG
Burkhard wrote:Any reason why the loader.rb is inside the octane folder?
cu Burkhard
It's not :? - the files and sub-folders in the zip I posted ARE in the right relationships...
Read the Help PDF to see where files should end up.............
Download the zip again, don't extract anything immediately - check its contents against the files listed in the the Help file.
I omitted to update the README file about the 'sliders' - but I have now updated it in the zip... :oops:
You can download the ZIP file again if you want...
TIG
ameier
short feedback:
projekt path: starts every time at C:/Windows/system32
another stupid question.....
with the function animation there would be create many pics for eatch step. is there a way to get a avi directly.......? just watched your sample anim that you have post some days agoo. How does it work ? Did you use another tool ? Any hints would be welcome !
Burkhard
TIG,
Extracted the file on Mac: There are no folders.......by doubleclick on the zip files.
Just single files which are named in that way. ie. Octane/OctaneFolderBrowser/folder_browser.css
( It can happen when the zip was made with windows )
Choose the unarchiver or stuffit expander by rightclick ( open with...) it works with the folder structure.
Maybe it is worth to put this tip into the installation Readme file.
....and you've forgotten the octane_1022.rb in the Readme file
TIG
ameier wrote:short feedback:
project path: starts every time at C:/Windows/system32
with the function animation there would be create many pics for eatch step. is there a way to get a avi directly.......? just watched your sample anim that you have post some days ago. How does it work ? Did you use another tool ? Any hints would be welcome !
The 'project path' in the main dialog should initially default to the SKP's folder... Are you saying that when you start a brand new [just saved] SKP it doesn't start there ? It does on my PC [Vista] - what is your OS etc ?
If the specified folder that is currently shown in the text-box doesn't exist then when you 'Browse' the folder-browser dialog will default to the 'current working directory' - I am surprised yours is '../system32/' :? - Usually it's '../Plugins/'
The animation makes a series of png images each based on a scene in order [to add scenes use one of the 3rd party SUp tools freely available] - you then need to assemble these images into a movie using something like Microsoft's "Windows Movie Maker" [free] - it's pretty easy to do... :geek:
TIG
TIG
Burkhard wrote:TIG,
Thanks for the Mac tip I'll add it - I'll also add that missing file in the README :oops:
EDIT: I have updated the ZIP in the first post to include clearer instructions on extracting the files keeping their sub-folders on the Mac etc - the README and Help PDF are both updated- there are no other substantive alterations to code etc :geek:
TIG
radiance
Hey,
great release i manage to export perfect scenes, with everything propperly exported.
the only remaining issues i have:
* navigation if octane is launched from the plugin is broken (eg panning is 10x too slow, i will investigate this on our end tomorrow, are you giving octane a normalized camera up vector ?)
* the error when launching the plugin, i just hit ignore/continue. I'm running google chrome on win 7 x64 and the IE version is the default that came with my windows install (i never use IE))
one last thing i noticed, sketchup uses the alpha channel in some images like textures for leaves.
i can, in octane, take these textures and make a black/white mask of them in photoshop and stick it in the opacity map slot so the tree leaves are correct.
in beta 2.3, we'll have a new texturenode, an alphaimage texture node, which takes the alpha channel of a file format that carries one (like a PNG) and functions like a floatimage, but it returns a black/white texture of the image file's alpha channel.
since this is still a while off, i'm not sure if it's a lot of work, but if it is'nt you might consider making a functionality where you write out a black and white mask and use the map_d functionality in the MTL file to give the opacity map so vegetation comes through perfect by default ?
Radiance
Return to “SketchUp”
