Testing skin rendering in Octane. 3D scan model from http://www.3dscanstore.com/index.php/default/freescan
Just one color map used. It is just a simple Specular material. Looks pretty good out of the box !
I have attached the scene. Just grab the obj and texture from the ten24 link.
Skin surface
- BorisGoreta
- Contact:
- Attachments
- 3D scan.rar
- (5.24 KiB) Downloaded 218 times
- boeing727223
Cool, so this is just a texture map plugged into specular with no SSS? Nice job!
Thank you so much for providing the OBJ - it is amazing!
- silviotoledo
How much time to render? How many SSS layers?
For mine? I think it was around the 2 min mark, but I only have a GTX 550Ti. SSS was as per http://poserphysics.blogspot.com/2012/1 ... hader.html, but with the bump removed and the scale at around 1. Slight modification to the glossy too.
- silviotoledo
Thanks face_off
I'm planning acquire octane render for massive character rendering when the lightwave plugin will be available. Last face close up I tried using lightwave SSS required 30 minutes rendering on an i7 processor.
BorisGoreta, have you tried the same render on lightwave itself? How about your rendering time?
Silvio Toledo
Silvio Toledo
