OctaneRender® for Maya® beta 3.03f [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
This is the "quick-fix" version.
BUG FIXES SINCE LAST RELEASE:
  • Fixed the "movable proxy particles not rendered" bug.
  • Added the "almost finished frame" endless cycle workaround (jmfowler reported).
  • Few minor bug fixes...
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
jmfowler
Please check if this release will work OK on your rig.
If the second frame will be rendered OK with this version - please, look at the Octane output (it is important to sort out one thing for me): do you see the warnings like "Octane: rendering has stopped at 7999 spp (from 8000)"?
TBFX
Thanks JimStar.
All good now for me.
T.
Joss
"// Error: Octane: Error in mesh function set constructor of mesh: "|static|plate_shards|shard40|shard40Shape" //
// Error: Octane: Error mesh export. Octane render stopped. // "
Geometry is procedurally generated shards, it looks like some of them contains degenerated geometry, i.e. it's a mesh with 0 points.
I think would be nice to just continue mesh translation on such errors.
Freelance CG TD, developer.
ruhi
how can i render animations?
Joss wrote:"// Error: Octane: Error in mesh function set constructor of mesh: "|static|plate_shards|shard40|shard40Shape" //
Yes, it is reasonably. I will change to this behaviour in next version...
ruhi wrote:how can i render animations?
It is not the plugin related question.
You should do it standard Maya's way. Perhaps you need to learn how to use the Maya user interface: the square next to the option name is for options window opening (related to this option). And as Octane does not need any additional options for batch render in addition to standard ones - it does not have these options, and says about it if you press this square instead of just starting the batch render (the Maya's standard "Maya Hardware" and "Maya Hardware 2.0" renderers do the same).
jmfowler
ALL HAIL JIMSTAR!! - You fixed it! - rendered lots of animation frames sequentially on the 580 and 680's without a problem last night - Sweet!
thanks
out of curiosity - what was/is the bug that makes it fail like it was?
jmfowler wrote:ALL HAIL JIMSTAR!! - You fixed it! - rendered lots of animation frames sequentially on the 580 and 680's without a problem last night - Sweet!
thanks
Answer my question please...
jmfowler
the following image was the message that I was getting , but now there's no problem.
see where it says "7999 samples per pixel of 8000" it was then continuing to says this indefinitely without moving onto the next frame.
Return to “Autodesk Maya”
