Can't launch Octane error
ASyme1
This is a cool plugin. I've gotten everything to work earlier today, but right now the plug is telling me it can't launch Octane when I hit render. Anyone else have this problem?
Alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
abstrax
ASyme1 wrote:This is a cool plugin. I've gotten everything to work earlier today, but right now the plug is telling me it can't launch Octane when I hit render. Anyone else have this problem?
Alec
Can you launch Octane manually? Have you checked the path of the Octane binary? Is there any other instance of Octane running? When you click on the render button, does anything happen? What is the command line? You see it in the console window of CINEMA 4D.
Marcus
ASyme1
Marcus
Yes, I can launch it manually. Path is good. No other instances running, no. When I hit the render button it spins for a couple seconds and then says, "Could not launch Octane". That's it.
Alec
Alec Syme
abstrax
ASyme1 wrote:Can you launch Octane manually? Have you checked the path of the Octane binary? Is there any other instance of Octane running? When you click on the render button, does anything happen? What is the command line? You see it in the console window of CINEMA 4D.
Marcus
Alec
Does it happen with any scene also with new scenes? Could you send me a screenshot of the C4D console window?
Marcus
ASyme1
Hi Markus-
I think I figured out why that scene wasn't opening. I was trying to work with it from a network server. No dice. Once I put it on my local machine it worked great. Does this software not like working over a LAN?
Alec
Alec Syme
abstrax
ASyme1 wrote:Hi Markus-
Alec
I don't know. Will try it tonight and see what happens :)
Do you mean Octane was on the network server or C4D or the scene?
Marcus
ASyme1
Octane.exe is on my local C drive. I was attempting to run a C4D project off the server. The Octane project file was also on the server.
Alec
Alec Syme
