Hi all,
In the standalone version I can set the power of the texture environment when using an image. This is great to boost up hdr images for environment lighting.
How do I do this in the 3dsmax plugin version? (Not to be confused with the power of the image texture, which is a maximum of 1.)
How to set the power of the texture environment?
- MaTtY631990
First click on the 3dsmax environment tab and place a Texture environment node. Then drag/instance to material editor. Thats it. You will
see parameters for texture,power and rotation.
