Hi octane team, may the treaded voxelizing to fall into oblivion because working on other features.
It would be a huge improvement for rendering stills an animations to speed up octane.
Cheers, mib.
Feature Request: Multitreaded Voxelizing
- mib2berlin
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
It also eats memory. I have maxed out my 16 quite often recently which results in Octane just falling over.
(OS) Windows 7(64)
(OS) Windows 7(64)
I thought it was !
+1 obviously !
+1 obviously !
not sure if voxelizing is done in the builtin octane plugin for 3dmax or others on a single core also - it doesnt eveb show the time it takes to voxelize - but its a lot quicker, seems like at least 50-70% speed up, and a smoother workflow really brings it to another level - so if nothing else that's the solution to wait out
- it is a waste of resources with no multithreading in any case, I thought they knew better than that, hope it does not require a complete rewrite of octane code - which they already done a few times..
so if you have a 4xHT CPU, you end up with 8 virtual cores, and then you use a single virtual core to do the processing - that has the 1/2 power of a single core - ends up a 12.5% CPU usage doing it on a single core, (and I wanted to upgrade to 6 cores in some time - not worth it still)
- did anyone test if the speed goes up if you disable hyperthreading in BIOS?
..also check out this Arion has voxelization disk cache - reuses same info on camera animations - thats a good trick
3dmax, zbrush, UE
//Behance profile //BOONAR
+1 to multi threaded voxelizing, 6 cores ready to do something.
