Cuda`s
whersmy
Hi everyone,
Does anyone know if this is possible? I know some GPU-based renders use up 100% of the GPU, so you can`t navigate through windows, unless you have a second GPU for the monitor. (which in my case would be the integrated non-CUDA HD4000 of my 3770K)
Greetings from Amsterdam
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
i can tell nothing about the solidwork workflow but i can confirm that the HD4000 works pretty well with monitor attached and you can play with the cpu at 100% while octane is rendering ;)
it's time to update my signature :)
whersmy
When I have Octane I will do tests.
theoretically is possible, but it must to be said that octane needs the cpu during the voxelization process, so some power is lost every frame :roll:
acc24ex
why use keyshot for importing solidworks - isnt it mianly for rendering? I recommend moi3d - cheaper, and it has the best ever poly output - or autodesk inventor - import solidworks parts and save as inventor assembly and then import that into 3dmax, everything looks native like modeled in solidworks in that case (works in 3dmax2013) -
anyway - it could work, but it would be much better to use another GPU for monitor and other for GPU rendering
you know what the problem is, gpu rendering uses almost 100% of gpu processing power, so it had problems with updating the screen it is also connected to
so if you use keyshot for stills and octane for animations - it could pretty much work - the only problem is that updating of monitor issue - you would still have some lagging even with two or 4 GPUs - but it could be managable, when you use PMC kernel, it works like there is no lag at all
whersmy
I tried moi3d.
acc24ex
..actually moi3d sometimes has troubles when exporting directly to .obj and then rendering in octane (sometimes inverted normals and sometimes missing faces - true that, but it produces Ngons at least - most programs produce triangles so that is probably why)
- so I would export it to .fbx and import back into 3dmax, and then use the 3dmax octane plugin, not the standalone -
and if you want to buy the 3dmax plugin you also need to buy the octane standalone version
so I guess your original workflow should work just fine (if .obj exports are fine)
- you know you still need 3dmax or something to change the UVW mapping at least, not sure if youre using 3dmax at all or is it just for exporting - because you could use autodesk inventor to open the parts from solidworks and save them again in inventor assembly format and import that into 3dmax - I tried that with a few models, works pretty nice and quick, 3dmax will recognize the parts as "body objects" - never seen that before - you can change the quality of poly conversion there (and inventor looks and feels almost exactly like SW)
open inventor (import SW and save as inv.) > 3dmax (with octane plugin)
that looks like a faster workflow, you dont even have to export the SW files or have SW installed in that case..
either way, the thing should work
whersmy
Cool, will see if I can get a hold of Inventor.
So far I made a list:
- Model in SW, put it on the bottom of the front plane in SW
- Increase tessalation
- Save a STEP
- Import Moi3d
- Export .Obj
- Import Octane
- Reduce res if needed (performance, handling)
- Decide for DL, PT, PMC
- Add the right lightining
- Add materials
- Only render alpha (instead of background too) (SAVES rendertime)
- Render shadow with total diffuse materials on 1/2 size original render
- Combine both renders in Photoshop
Result:
gabrielefx
whersmy wrote:Cool, will see if I can get a hold of Inventor.
- Save a STEP
- Import Moi3d
- Export .Obj
- Import Octane
- Add materials
Result:
why all these steps?
Solidworks does not save in obj?
