OctaneRender® for Maya® beta 2.58l [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • Fixed one more LiveDB bug.
  • "sourceimages" directory is now created if does not exists when getting material from LiveDB.
  • Fixed Octane Nodes duplicating issue.
  • Minor fixes and improvements...
NEW FEATURES SINCE LAST RELEASE:
  • Added "Refresh" button to LiveDB window, it is needed sometimes if the previous attempt of downloading LiveDB data failed.
  • Material nodes are checked now before render to have unique names (to not interchange inside Octane engine).
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
jmfowler
Thanks Jimstar your awesome! - Keep going!!
renmaxhb
HI,
I found a big problem,scence can be Ipr or bacthrender if materials has none texture, but scence can not bacthrender and can be Ipr if materials has any textures.
Oh MG,I tried many times ,it is always like this.I have a imperative rendering ,please help me!!
I send the scence to you.
test.rar
(998.13 KiB) Downloaded 306 times
renmaxhb wrote:HI,
Thanks for report!
I will check it right now, and if it is the bug, I will release the "quick fix" version today.;)
renmaxhb
Thanks,I am waiting for you :roll:
renmaxhb
I've found the reason of your problems, get the next "quick-fix" release please.;)
Next version HERE.
Return to “Autodesk Maya”
