OctaneRender® for 3ds max® v1.0 beta 3.00b[Test]
Karba
Otoy® is proud to announce the availability of a new version of OctaneRender® for 3ds max®: Version 1.0 beta 3.00b.
The world's fastest and most feature-rich unbiased render engine that integrates completely into Autodesk® 3ds max®.
This version is not stable, don't use for important projects.
3ds max® Version Requirements
This release will only work with 3ds max® Versions 2010, 2011, 2012 & 2013/ 32bit & 64x / Base & Design on MS Windows operating systems.
OctaneRender® for 3ds max® implements all functionality of OctaneRender® standalone inside 3ds max®.
Any feature that the Standalone edition supports is supported by the 3ds max® plugin.
To run OctaneRender® for 3ds max®, you need to also have an activated OctaneRender® Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the 3ds max plugin and use it without also owning an activated copy of OctaneRender® Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
If you do not own an OctaneRender® Standalone Edition License yet:
You can purchase both the OctaneRender® Standalone Edition and the OctaneRender® for 3ds max® Edition as a reduced price bundle, purchase the bundle priced at 179€
If you already own one or more OctaneRender® Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender® for 3ds max® v1.0 Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender® for 3ds max® licenses,
just like OctaneRender Standalone Edition packs.
INSTALLATION INSTRUCTIONS
At this moment there isn't automatic installation. You have to copy files to 3ds max manually.
Please read the installation text file included in the download ZIP file archive.
OCTANELIVE®
Just like OctaneRender® Standalone, The 3ds max® plugin product also needs an additional octanelive license and be activated on a machine.
This has to be done in the plugin interface panel in 3ds max, and is covered in the included PDF manual.
It can only be done after an OctaneRender® Standalone license is already activated on the machine in question.
BUG FIXES SINCE LAST RELEASE:
  • 3dsmax crash after object modifier applying.
KNOWN ISSUES:
  • Incorrect lighting distribution (random bug). (standalone issue)
  • Incorrect material preview in case render is not running. (standalone issue)
  • Memory leak. (standalone issue)
  • Don't support old GPU models.
DOWNLOAD
We have 4 separate archives available for download, for Autodesk® 3ds max® 2010, 2011, 2012 and 2013.
Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
so you only need to dowload one archive for your 3ds max® version from the following download links:
3ds max® 2010: http://www.refractivesoftware.com/plugi ... _3.00b.zip (50MB ZIP File)
3ds max® 2011: http://www.refractivesoftware.com/plugi ... _3.00b.zip (50MB ZIP File)
3ds max® 2012: http://www.refractivesoftware.com/plugi ... _3.00b.zip (50MB ZIP File)
3ds max® 2013: http://www.refractivesoftware.com/plugi ... _3.00b.zip (50MB ZIP File)
Yours,
The OctaneRender® Team.
andrian
Great, thanks.
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
gabrielefx
thank you, I will check this release.
Karba, could you add support for image sequence loaded as texture?
Regards
Karba
gabrielefx wrote: Karba, could you add support for image sequence loaded as texture?
Regards
At this moment I have no idea how to do this support.
I will think about it.
nildoe
thx alot karba!
its kinda reassuring to know that the bugs about light and others is in the standalone :).
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
gabrielefx
Regards
You know that Max uses the ifl file to collect the sequence, you could use these informations.
nildoe
Image sequence would indeed be a great PLUS! in the case where we can use animated tree maps to save on geometry and other situations would be very nice.
I was just going to mention the ifl file type as well :).
Nildo
HHbomb
hello
beta 3.00b looks fine and no more crash :-)
I have just some questions :
- I don't find OCTANE in customise menu
- how to render trees with forest lite (i can just show proxies) or need forest pack ?
- could it be possible to use multiscatter with octane one day ?
Thanks.
ooppps : one crash...
Philipp1980
Hi everyone!
I have a stupid question: I can't find the octane properties. If i right-click on an object, the octane properties are not listed there, also not in the object properties window.
Am I doing something wrong? :cry:
Thank you in advance...
petergazo
3ds max plugin doesnt work with IES either. I have tried 3 different scenes, never got correct lightning.
i5-2500k | 16GB ram | gtx460 2GB (display) + GTX580 1.5GB | Win7 pro x64 | v1.0 beta 3.00b | http://www.behance.net/petergazo
Return to “Autodesk 3Ds Max”
