Here is a quick test using the export of instance matrix to a scatter file as I mentioned in the blender plugin section.
The workflow is a bit tricky but all in all it can be usable, the main goal was to see how Octane manages such high volumes, I find the rendering a bit slow but still ok.
The scene uses about 1.1 Gb of VRAM and has about 5.5 milion polys with instanced objects
Instanced object :
Grass generated from particles, about 2.2 milion faces
5 Different trees scattered based on Blender instances, only the parent object (trunc) is duplicated in Blender and is used as proxy
If I find some time I will test with another scene with some heavy forest on background, the Greenhouse scene could be great to populate with lot of plants and trees ...
Blender and instances quick test
- enricocerica
- Contact:
http://www.myline.be
Great to see instances working out of blender. Is it possible to add some random z rotation? It would look much better.
n1k
n1k
- Elvissuperstar007
- Contact:
so interesting..I should post to Karba about Max handling so much without issues..I know my actual spec is not the highest but reading this does make me think..Elvissuperstar007 wrote:http://www.blendernation.com/2012/03/23/19-billion-triangles-render/
I'm a 150% Rhino designer but I'm getting intrigued by Blender recently..lazy though to start learning again...
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
