Octane exporter for C4D 0.01
abstrax
Hi all,
I think/hope I have now a robust OBJ/MTL export working. Materials get exported only as diffuse material with the average colour as diffuse colour. And no polygon selections are supported. But the actual geometry and UV export plus name mangling and other things should work fine:
To export a scene, just click on Plugins -> Octane Export. You can then specify project name and directory in the dialog that shows up and then you have to click on "Export OBJ/MTL only". The render button is not functional as well as the export configuration and animation groups. Tomorrow (well, actually this morning) I will provide a Mac build. After that I will try to call Octane from C4D and then to pass the export options of the dialog.
These are the PC builds of the plugin:
CINEMA 4D R9.6 (32/64bit):
OctaneExport_0.01_win_r9.6_release.zip
(115.28 KiB) Downloaded 529 times
CINEMA 4D R10.1 - 11.0 (32/64bit):
OctaneExport_0.01_win_r10.1_release.zip
(115.45 KiB) Downloaded 570 times
CINEMA 4D R11.5 (32/64bit):
OctaneExport_0.01_win_r11.5_release.zip
(194.9 KiB) Downloaded 596 times
These are the Mac builds of the plugin:
CINEMA 4D R9.6 (32bit):
OctaneExport_0.01_mac_r9.6_release.zip
(88.49 KiB) Downloaded 543 times
CINEMA 4D R10.1 - 10.5 (32bit):
OctaneExport_0.01_mac_r10.1_release.zip
(125.87 KiB) Downloaded 538 times
CINEMA 4D R11.0 (32/64bit):
OctaneExport_0.01_mac_r11.0_release.zip
(257.7 KiB) Downloaded 545 times
OctaneExport_0.01_mac_r11.5_release.zip
(286.66 KiB) Downloaded 581 times
Marcus
mat536
Fantastic!
Thank you.
Thank you.
Thank you!
Mark
Core i7 920 - 2.67 GHz | Win 7 Pro 64Bit - 12 GB RAM | GTX275-896MB - driver v.197.45 | 150 GB Raptor 10K HD | Octane 1.022 beta 2.2 |
mantra
YEAAAAH!!!!
MY WORKS
Cinema 4d | Win7x64 | 450gts
russian octane community
http://vk.com/octanerender
mantra
works perfectly, waiting for updates
MY WORKS
radiance
thanks marcus, great work :)
Radiance
mantra
I did the translation into Russian.
Plz, include it in the distribution for Russian users
strings_ru.zip
(1.96 KiB) Downloaded 553 times
MY WORKS
pixie
Thank you! :)
ribrahomedesign
thank you .
i have a question ,it looks to me that when you have a object with more then one texture applied ,the
exporter only exports one texture , is that wright ?
and a dump question , what is the Octane Render Binary for ? i dont understand
regards
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
radiance
ribrahomedesign wrote:thank you .
regards
Rico
the octane render binary is how the script finds octane.exe, so it can start it.
you should enter the path to where it is installed.
it's in the screenshot above. (the default installer location)
about the textures -> i can't answer that you'll have to wait for abstrax to reply ;)
Radiance
pdavid
A big thank to you abstrax , this is very nice of you.
windows 7 64|Gigabyte X79-UD3 | Intel Core i7 3930K| (2) GTX TITAN|(1)GTX 670|psu 1200 watt|16gig ram|
