How does Octane render quality compares to modo rendering for example?
How close are they?
Octane vs Modo
http://www.mduque.com
"To lose ambition is to lose yourself."
Win 7 Pro 64 bits | Core i7 860 - 2.8 GHz| Gigabyte P55A-UD4 | 8 GB | Quadro FX 4800
If you manage to render a photo realistic cup in both, then they are exactly the same in quality. If you throw a terrible model and texture into Modo and a brilliant model and texture into Octane, Octane will produce a better quality render every time.
The point is, there's more to rendering than the start button. Octane is unbiased, and extremely fast at producing clean renders. Give it a try and see if it can, in your hands, produce the quality of image you're after. If it can't and Modo can (and you like to wait) choose Modo. Easy.
- bluescorpion
Any comparison is only meaningful if they are apple to apple.
modo is biased and Octane is unbiased.
I would also like to know the answer to CGicore's question but I would appreciate if the comparison can be broken down into:
1) modo (biased) vs Octane (biased)
2) modo (biased) vs Octane (unbiased)
MacPro 2.8Ghz Dual Quad-Core Intel Xeon; 18GB Ram, Nvidia GeForce 8800GT; Mac OSX 10.6.4
- PhilLawson
Modo can also be unbiased and is in fact, by default, using an unbiased method of sample distribution. Unbiased simply means a perfectly distributed random noise of sampling in the cases of rendering. Octane's main benefit over modo is that is is a physically based spectral renderer as well as being mighty fast for being so.
A good image rendered is a good image rendered, but if the job demands accuracy, then spectral renders are the way to go.
Cheers.
Cheers.
Vista 64bit | Nvidia 580GTX 1.5GB | Intel Core Quad 9550 2.83GHz | 8GB RAM
