I have no control over the camera, please help.
Isn't there a way to mimick host application camera behaviour via a switch.
I would like rhino 3d like control>
view adjustment doesn't work
- Duke_Arnout
- Contact:
E6400 2x gtx 570 8gb ram xfx 680i LT windows vista 64bit
I don't understand why you don't have control, can you explain in detail ?
Are you sure you're importing in the right scale ?
Check your modeling scale and make sure the scale is set correctly in the OBJ import preferences panel in octane's file menu.
Radiance
Radiance
- Duke_Arnout
- Contact:
i will try to increase the scale but till now I can't rotate the camera, it rotates around an axis trough the camera lens. I would like to have first person control
- Duke_Arnout
- Contact:
I export via rhino, scale adjustment to metres help in a different area, image quality is better now but the view keeps rotating via an axis through the camera if you understand what I mean
- Duke_Arnout
- Contact:
I would not want to revert to my host app constantly to adjust the view
- Duke_Arnout
- Contact:
it is like a clock, the whole environment goes like the pointers of an analoge clock
- Duke_Arnout
- Contact:
in the demo scenes the camera works ok.
Is there a template you could provide me with that works and isn't to taxing on the system.
I don't seem to be able to put my mesh in the demo suite, it is quite big.
Sometimes when loading in big meshes octane crashes, do I need to load them in in parts?
just need to get comfortable with the demosuite first, then try to get a simple object in the right scale into octane.Duke_Arnout wrote:in the demo scenes the camera works ok.
then, try to push more vertices and see where it leads...
Radiance
