Is there a limit to the number of textures allowed in a scene?
Is it dependent on the graphics card specs?
Is this something that will eventually be corrected or is this a GPU renderer limitation?
Texture limit?
There is currently a limit on the number of textures you can use in a scene for rendering, these are 64 RGB textures and 32 grayscale textures. There are some workarounds, like using texture atlases or using procedural textures if possible.
Roeland
Roeland
there is in fact a limit, set from cuda, not octane: 128 textures at max. currently octane divides them into 64 rgba, 32 bw, 4 rgba hdri and 4 bw rgbi.Pullakk wrote:hmm...I am not using the whole memory.
- LudovicRouy
- Contact:
Thanks for these infos !
I have these models of cars in which each part has a separate map.... 10 -15 maps per car....and I was inserting them into a scene already full of maps when suddenly maps starting disappearing..every new map I add, one disappears.
Thank God for these forums.
i7 2600K (P8P67-Pro), 8GB, GTX580 3GB
