Texture limit?
Pullakk
Is there a limit to the number of textures allowed in a scene?
Is it dependent on the graphics card specs?
Is this something that will eventually be corrected or is this a GPU renderer limitation?
i7 2600K (P8P67-Pro), 8GB, GTX580 3GB
Karba
Pullakk wrote:Is there a limit to the number of textures allowed in a scene?
limit is only your video memory
Pullakk
hmm...I am not using the whole memory.
roeland
There is currently a limit on the number of textures you can use in a scene for rendering, these are 64 RGB textures and 32 grayscale textures. There are some workarounds, like using texture atlases or using procedural textures if possible.
Roeland
t_3
Pullakk wrote:hmm...I am not using the whole memory.
there is in fact a limit, set from cuda, not octane: 128 textures at max. currently octane divides them into 64 rgba, 32 bw, 4 rgba hdri and 4 bw rgbi.
LudovicRouy
Thanks for these infos !
Pullakk
I have these models of cars in which each part has a separate map.... 10 -15 maps per car....and I was inserting them into a scene already full of maps when suddenly maps starting disappearing..every new map I add, one disappears.
Thank God for these forums.
Return to “Autodesk 3Ds Max”
