Hi all
In Octane Render, how can i create the leaves/grass transparency? Does i have to use .tga with an alpha channel - like in video games, or use 2 images(a difuse map and transparency black and white map) like in standard renderers?
leaves and grass transparency?
Sys:
Windows 7 x64 Ultimate
CPU: AMD Athlon X2 7750 BE(2.7GHz)
GPU: nVidia 9800 GTX
RAM: 6GB DDR2
RAM: 6GB DDR2
- WiKKiDWidgets
Currently you have to use a Opacity map for this. .PNG alpha support is on the horizon.
Vista 32 (<--EEEW!)| Intel Quad Q6600 2.4Ghz | 4Gb ram | Dual NVidia GTS 250 1Gb (Non-SLi)
ok, basiclly i have to create two images one is a diffuse and with the other (opacity) i get the transparency.
Basiclly is the same as in XSI. Ok thnx a lot
Cya
Cya
Sys:
RAM: 6GB DDR2
RAM: 6GB DDR2
Really ? Good news !WiKKiDWidgets wrote:Currently you have to use a Opacity map for this. .PNG alpha support is on the horizon.
