Hello,
I have a small problem with the emitter ...
As you can see from the picture, the light is projected above and not below.
Is there a way to reverse the direction?
Thank you!
Light emitter-direction?
- Jaberwocky
yes
turn the plane mesh that's being used for the emitter through 180deg.it looks like the normals are pointing upwards.Therefore the emitter is emitting the light in the direction of the normals.
Hope that helps
Jaba
Hope that helps
Jaba
turn the mesh or flip the mesh normals
Thank you.Jaberwocky wrote:yes
Hope that helps
Jaba
I will try.
Bye
"Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie"
Leonardo da Vinci
Leonardo da Vinci
Thank you.Refracty wrote:turn the mesh or flip the mesh normals
This is also very interesting.
You can do this inside of Octane?
Ciao
Leonardo da Vinci
Leonardo da Vinci
No you can't. I hope you will be able to do it in a future release.
Thank you.
I hope so too.
I solved by working in the modeler.
Bye
I hope so too.
Bye
Leonardo da Vinci
Leonardo da Vinci
