Light emitter-direction?
m_m_
Hello,
I have a small problem with the emitter ...
As you can see from the picture, the light is projected above and not below.
Is there a way to reverse the direction?
Thank you!
"Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie"
Leonardo da Vinci
Jaberwocky
yes
turn the plane mesh that's being used for the emitter through 180deg.it looks like the normals are pointing upwards.Therefore the emitter is emitting the light in the direction of the normals.
Hope that helps
Jaba
Refracty
turn the mesh or flip the mesh normals
m_m_
Jaberwocky wrote:yes
Hope that helps
Jaba
Thank you.
I will try.
Bye
Leonardo da Vinci
m_m_
Refracty wrote:turn the mesh or flip the mesh normals
Thank you.
This is also very interesting.
You can do this inside of Octane?
Ciao
Leonardo da Vinci
Refracty
No you can't. I hope you will be able to do it in a future release.
m_m_
Thank you.
I hope so too.
I solved by working in the modeler.
Bye
Leonardo da Vinci
