Hello,
I'm new with octane and there is no manual I can learn this software from so I have to rely almost exclusively on video tutorials and forums.
Whenever I'm using emitters in directlighting mode I get certain "unbaked" areas. such as the example posted. Can you please explain what do I have to correct?
Many thanks!
I7 8gb 2XGTX570 Win7
Nasty dots filling the rendering in certain areas
- arian.mares
You mean the white pixels?
I would try to simplify the emitter, best to use only a single plane.
Look that the emitters aren´t cut any other polygon so they are fully outside.
Play with the samplerate in the emitter settings.
And if nothing helps, try to increase the max samples.
face
face
http://vimeo.com/user2509578
- arian.mares
face wrote:You mean the white pixels?
face
roeland wrote:It looks like there is a small emitter above the table, it is probably this emitter that is not sampled adequately. Does the noise improve if you increase sample_rate for this emitter?
Roeland
I can't draw a single plane with this software... yeah, the emitter has volume. I'll assign a different material on one side alone and this is it. As for the samples, I stopped the rendering at about 6000 samples which is a lot even for this resolution.
Thank you kindly for your prompt help. I will keep you informed with the progress I made.
