Hey all,
I'm using the demo right now, while I wait for my license to come to fruition.
I'm exporting from Blender to the WaveFront format. When I load the Obj file in octane, it shuts down during the Voxelizing stage. Has anyone else had this trouble and con point me in the right direction?
Thanks very much.
Octane Shuts Down When Voxelizing
- understand
mm maybe you got some polygons that aren't 3 or 4 sides or some floating vertices
Win 8.0 64-bit | Gainward 460 GTX 2048mb (driver: latest) | Phenom 965 3.4ghz 140w | 12GB
Win 8.1 64-bit | EVGA 780ti Superclocked 3072mb (driver: latest) | i7 4930k 3.4ghz | 32GB
Win 7 64-bit Bootcamp | 650M 1GB (driver: 327.23) | i7 2.7ghz | 8GB
- SurfingAlien
with low-end cards (see my sign...) it might be a memory issue too I think
MacBookPro unibody 2x2.4GHz | 4Gb | 9400M+9600GT 256Mb | OSX 10.6.8
i7 2600-K @3.4GHz | 8Gb | GTX560Ti 2Gb | Windows7x64 | Octane 1.0 b2.52
- greg.thoman
All good suggestions.
I'm running a GTS 250 with 1Gb memory.
I'm not sure if this is a "low end" card or not.
I've been exporting as Triangles. I'll keep at it. Thanks for the suggestions!
AMD Phenom II X6 3.2 || 12 GB DDR3
GTX 480 1.5GB X 3 Liquid Cooled
RaidMax 1000W PSU || Corsair 850W PSU
MSI NF890-G65 Mainboard || Windows 7 64 Bit
- greg.thoman
I have windows 7 64-bit with 8 Gig of Ram
Thanks for the advice.
you should use the x64 version then.greg.thoman wrote:I have windows 7 64-bit with 8 Gig of Ram
if there are still issues during voxelising, make sure, like phil said to export your model as triangles.
Radiance
- simmsimaging
I've had this happen a lot with high res meshes too. At this point I'm kinda holding off playing with Octane till I can get a bit more stable workflow with hi-res meshes and fairly high res renders (for me 4K is bare minimum)
b
b
it's about time nvidia released 3GB fermi cards.simmsimaging wrote:I've had this happen a lot with high res meshes too. At this point I'm kinda holding off playing with Octane till I can get a bit more stable workflow with hi-res meshes and fairly high res renders (for me 4K is bare minimum)
b
Radiance
