35mm film with octane
[gk]
35mm film with 50mm canon prime lens @ 1,4 f/stops ,camera stoped to 5,6 with octane rendered logo.
http://www.droschler.dk/permanent/octane/gk/
Amiga 1000 with 2mb memory card
radiance
amazing ;)
can you explain more about how you made it ?
did you use the same manual technique ?
i can add some automated OBJ based command line flags for beta2.1 update to automate this if you want.
Radiance
[gk]
cool beans, anything that eases animating will be wellcomed :)
Different technic this time.
Br1
radiance wrote:amazing ;)
Radiance
Please, please, please ... ! That would be great !
[gk]
n1k
Looking nice:)
[email protected], 8gb RAM, Gainward GF 460 GTX 2048mb,Win7 64bit.
http://continuum3d.blogspot.com/
mlody47
gk buy Octane or I will buy it for You !!!!!
I like your way of thinking ;)
i7 2600K + 2X gtx 580 + GTX 560 Ti + 8gbram + Win7 +
AUTODESK SOFTIMAGE 2012
www.behance.net/mlody47
justix
gk that was really interesting ,would be extremely generous of you a short how-to... ;)
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Tugpsx
second that request
[gk]
Ok,
Ill remove the mystery and reveal a range of hacks then :)
- I ran outside and made the 35mm footage of the concrete pole in focus.
- I made sure there were little to no paralax because I knew the more paralax the harder it would be to maintain a belivable optical output.
- Dumped the HD footage and cut out around 200 images.
- Burned them to a jpg sequence while maintaining the raw footage in the master composition.
- Used Boujou to nodal-pan track ( as there were no paralax ) the footage.
- exported the camera and point cloud to 3dsmax.
- made the logo and did a few test renders to verify intergrity.
- exported the logo to obj
- imported it to octane and had a light green flat diffuse background behind it.
- setup sun in same angle as it was in the footage.
- rendered 1 frame ;)
- screengrab'ed the logo on the green
- used a keyer to key out the green ( create an alpha channel )
- back to 3dsmax, used MAX2AE which can port camera/object relation to After effects in 3d space, snaped a control plane to the front of the logo and exported the sequence to AE
- back in AE, placed the octane render inside my 4 corner pin track
- back to max and render a matte/shadow pass on the top surface with brazil 2 area shadows.
- comped the shadows and the octane render together.
- colour graded with colorista
- played with gausian blur to add some focus pulling
- exported flv
- made a small flv output from the awesome film/image player from slideshow pro
- upload to net
- post link here ;)
