Hey Ahmet,
I noticed a bug with the Node Graph.
If you pick a node at a corner to scale it and then drag to make it smaller... If you drag far enough it will allow you to go into negative scale... after you have done that the node looks really messed up and you can´t select it anymore.
Raphael
Last stabile version 2.06.1 - (09.09.14)
- Silverwing
- Contact:
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
Nested Renderinstances seem to not work in: 2.04, 2.06 and 2.10. Nested are Renderinstances in a Cloner wich also has ri active.
Is that still, or did it work until now?
| Win 11 | 64 GB RAM | AMD 5900X | RTX 3090 24 GB | C4D R21 | C4D-Octane v2026.1 |
Yes, cannot support it yet. It's very complex for realtime updates.dinf wrote:Nested Renderinstances seem to not work in: 2.04, 2.06 and 2.10. Nested are Renderinstances in a Cloner wich also has ri active.
Hello,
Noticed another node graph glitch, you cannot link turbulence node to invert node, but if you go from turbulence to clamp or mix.. then you can link that to invert.
OK thanks. It seems to be on your list, that is important to me.aoktar wrote:Yes, cannot support it yet. It's very complex for realtime updates.dinf wrote:Nested Renderinstances seem to not work in: 2.04, 2.06 and 2.10. Nested are Renderinstances in a Cloner wich also has ri active.
- Effekt-Etage
can the nodegraph be altered by xpresso, for example the range mapper node?
this would be a great feature.
you can connect any xpresso node to octane textures. But this will not be presentated on nodegraph editorEffekt-Etage wrote:can the nodegraph be altered by xpresso, for example the range mapper node?
