Hi all,
This is last version of Cinema4D plugin. Plugin has several minor improvements/bugfixes over 2.05. Also i'm happy to reveal new Node Editor's test version. It can be accessed by "NG" button on Octane Window. Please don't forget it may not be safe for your critical works. It's still under heavy development and will be updated soon.
Enjoy it,
Ahmet
[vimeo]http://www.vimeo.com/105328990[/vimeo]
Windows version (R12-R15)
2.06.1: http://render.otoy.com/customerdownload ... .1-win.zip (LATEST)
2.06.0: http://render.otoy.com/customerdownload ... .0-win.zip
MacosX version (R13-R15)
2.06.1: http://render.otoy.com/customerdownload ... Macosx.zip (LATEST)
2.06.0: http://render.otoy.com/customerdownload ... Macosx.zip
Demo version is available in downloads section of web site
changes for 2.06.1
- fix a bug on livedb, which was making wrong values on internal floattex nodes
- imporovements on node editor: copy/paste, ctrl+mouse for duplicate nodes, material drop to LV(ctrl+alt+mouse move), several fixes/improvements
- Octane gradient node improvements, now it has simple and complex modes. Now texture connections is possible.
changes for 2.06.0
- fix for uvmapping on hair objects(Picture Viewer)
- Test version for Node Editor
- Targetted texture problems of Teamrender
- Several tweaks for workflow
- Some minor fixes
- Standalone 2.06 improvements
IMPORTANT INSTALL NOTE:
This version requires Nvidia driver 335.xx or newer(Cuda6.0).
Also matching version of Standalone 2.x is highly recommended.
And remove all old plugin files before installing. Any version conflict or old drivers can cause crashes
Cuda driver for Macos: http://www.nvidia.com/object/macosx-cud ... river.html
NET RENDER document: http://render.otoy.com/manuals/Standalo ... ge_id=1248
Supported features:
Displacement(activate with displacement checkbox in properties)
Hair rendering
Full motion blur for geometry and camera
Rounded edges
Opensubdiv
Render regions
Distributed rendering
Daylight+texture environment
Random color texture for instances
Demo scenes for 2.00
http://render.otoy.com/customerdownload ... amples.zip
Demo scenes for 1.50
Facebook page:
https://www.facebook.com/octaneforcinema4d
Bug reports:
I'll be happy, if anyone can be spesific with bug reports.
I need to know that plugin version/Os/HW, bugreport zip. Last operations before crashes.
Thanks for contributions
Best regards,
Ahmet Oktar
Last stabile version 2.06.1 - (09.09.14)
- AndreaMannori
Thank you Aoktar, Node Editor is very much appreciated!
Andrea Mannori
win 8.1 x64; nvidia 770M driver 340.52; octane standalone 2 + c4doctane 2.
thanks guys. I hope that you could solved the usage little bit. it's not so complex and works better while render session active in live viewer. I have still work to do, will be better soon
you're welcome.KeeWe wrote:Thanks a lot
Concerning the node System: Are there any advantges over the normal system? Can you achieve more? Or is it "only" another workflow?
this is a visual tool for features currently available. nothing is new yet. but I think that will expose to see power of current features. we had some limitation because of c4d gui. I'm going to try integrate better all features of Octane
I just updated to 2.06 and now i get ERROR: Could not connect to Server.
I work just fine yesterday and eben 2.05 isn't working anymore. Stan alone works just fine. Any idea what happened?:/
Edit: Disabled Kaspersky and now it worked, did you change something regaridng the activation process?
Edit2: Thanks for the info about the Node System^^
6850k // 32 GB // 1080, 1080 Ti, 2080 Ti // Win 10 // C4D 19.068
this process is not done by pluginKeeWe wrote:I just updated to 2.06 and now i get ERROR: Could not connect to Server.![]()
- shawnfrueh
The subdivision level in the object tag crashes cinema. when turned to 1 and rendered.
- Attachments
- _BugReport.zip
- Crash on render with subdivision
- (36.5 KiB) Downloaded 417 times
Hi Ahmet,
thanks very much for new version!
Node Editor looks very promising.
I know its the wrong section, sorry!
But what I really urgent would need is a node
for "saturation" and "color hue" like in the C4D-filter shader.
This would be such a great time saver.
If I try to use C4D filter shader, Octane/C4D crashes
Is this difficult to implement this?
thanks
MIke
thanks
MIke
